SketchUp crashes when entring value - D5 Livesync activated
Hello!
My SketchUp quite often crashes when I enter a value using push/pull or drawing geometry. The issue only occures when LiveSync is activated. It doesn’t matter what file I’m working on, large or small. I’m experiencing it also on multiple workstations.
Anyone having the same, very annoying, issue and how to solve this?!
D5 Render Version: 2.11
D5 Launcher-windows-1.0.0.0214
D5 LiveSync: 1.6.0.0015
Graphics Card: RTX 5090
Driver Version: 581.42
Windows 11
Hi @max
Does this issue only occur when using the push/pull tool in SketchUp? Apart from the tool, can you normally use both SKP and D5 without any problems?
I may need to request the following:
You may share it with me privately. Thank you.
