Sketchup camera view angle 3x wider in D5
D5 Render Version: 3
Graphics Card: RTX 3080
Driver Version: 32.0.15.9579
Issue Description: When I update a sketchup scene (latest ver of Sketchup April 2026), whatever the camera zoom is in Sketchup, say 39mm will come out very wide angle in D5. For example 13mm in D5, but set to 39mm in Sketchup view ( 39/3 = 13mm)
Each time I click the ‘Connect to D5 Render’ button, I get this result. Multiple different files and models, so consistent with an App issue, rather than a particular file.
Hi @bfreeman
Can you record a video demonstrating how to replicate this issue?
I tested it on my end, but I can’t seem to replicate it. I may have perhaps missed some steps.
I often wonder why I use ‘field of view’ of 90 - 100 degrees in D5, but in Sketchup the same effect only requires around 55-65 degrees. It doesn’t really bother me, I’m just curious.
Hi @3DG
You can try entering Sketchup.send_action 10624 in the Ruby Console to open the Camera window in SketchUp.
  • We support FOV (Field of View) value matching between SketchUp and D5, so you can compare and align the values in both applications. If the view doesn’t match exactly, try switching the FOV mode in D5 between horizontal and vertical, as this can affect the result.
Regarding focal length, it is indeed related to the FOV. However, it is not used in our mapping process, so you can safely ignore it when matching the views.
