Sending lights in new 3dsmax converter not instantiated
Hi guys
ive installed the new converter for 3dsmax (3.3 i think) but the lights ive sent to d5 are not being instantiated…Its a bug?
Hi mate, do you want the Light instances to be grouped automatically and the group date saved in D5 Render after sync? we have two different converter versions for lighting users, you can download the right one and try again.
Light group changes and different versions for downloading | D5 Converter for 3ds Max and SketchUp - Workflow - D5 RENDER FORUM
thanks! it worked like a charm!
Thank you for your update!
hi, can u please upload this 3.3.1.0051 version
Hello, could you please tell me why you need this version? If it’s because of the structure of the light component, the current version of this plugin has the option to sync or unsync.
58e959df-8ce7-4886-b4f9-f5c9403d50161
this option is available only in d5 live sync not in normal d5 sync plugin. and that live sync dont work. it hangs my 3dsmax.
Can you currently use 3d max livesync properly? Is it completely unusable?
no luck. even leah_li send me other version of livesync. that also didint worked. i’ll share one of my file, u may try on ur side.
its 3dsmax 2020 ver
Thanks, we will try it.
