Section fills
D5 Render Version: 2.5
Graphics Card: 3090
Driver Version: 536.67
Issue Description: SECTION FILLS MISSING ON SOME WALLS
Hi, mate, to confirm, are these faces broken, reversed, or overlayed? it will disappear due to it
I HAVE THE SAME SITUATION, BUT WORSE.
ONLY FRAMES WITH FILL.
ARCHICAD 26 EXPORTED MODEL
Hi mate, if you are sure the faces are ok(even rebuild and still not working), can you send this part of the model to us for troubleshooting? it’s a potential bug, thanks.
support@d5techs.com
Hello there,
I have the same issue. Walls have no fill. Hope there is a solution!
Regards, Paul
I found the problem: It occurs only when there is a surface override applied to the wall.
I tried Archicad 27 and problem is not solved, unfortunately.
