Ayudaaaaaa, saben porque no me deja guardar mi archivo y se cierra de la nada, completamente se borra todo lo que trabaje, con anterioridad si me dejaba utilizar D5 render sin ningun problema solo fue que se volvio a instalar el programa y ahora no me deja y se cierra repentinamente
Hi @jdeitar1700
Sorry to hear about this. Can you tell me which D5 version you’re using? Do both Ctrl + S and Save As not work? Can you see History Versions in the Launcher or open the file from Recents? When you say it deletes everything, do all materials and objects disappear? Also, where are you saving — locally, on a network, or in the cloud?
This will help figure out what’s causing the issue. Thank you
