Screen shivering only in D5 viewport
D5 Render Version: 2.7.1.0463
Graphics Card: 3080 rtx (laptop Legion7)
Driver Version: 555.85 nvidia studio drivers
Issue Description: Screen shivering only in viewport
please note that u will see shimmer only in the viewport area only, the rest of the window of d5 is absolutly fine, so definitely its not the case of a hot graphic card…please help in resolving this issue
Hello. Please check if your model is too far from the origin.
No, the model is at 0,0,0
I checked to import the same model into my office PC, and I am having no issues there…
will a fresh reinstall help this situation?
As I roughly remember, this issue started suddenly after I got the 5-day pro trial after updating my details in d5 website
We have just release a new version of 2.7.1.6465, you can try to update this version and check your problem again. If this problem happens again, please contact me again, and I suggest you can share your scene file with us. You can share a link here or send your file to our email. (support@d5techs.com, please describe the problem and attach the link of this post to your mail)
Is there any difference in configuration between the two computers you are using? Does this problem occur in scenarios other than the current one?
well trying to update didnt help at all…
So i totally uninstalled and used c-cleaner to wipe off remaining dlls and registry entries.
downloaded a fresh copy of the latest version and now my problem is fixed
Thanks for reporting and glad that your problem has been solved.
