**D5 Render Version:**2.3.4.0932
**Graphics Card:**RTX 3080 TI
**Driver Version:**522.25
**Issue Description:**applied a same material on wall panel some part seen as dark and some part light
Hi there, thanks for posting. From the screenshot, did you mean these two parts?
I think the difference is due to the lighting and shadows, you can add lights or adjust the exposure value then compare the result.
If we misunderstand your meaning, please kindly let us know it and we will follow up here.
Regards,
Oliver
i was not talking about side panels. i was talking about the drawer shutter which is highlighted in this image. whole drawer unit was given light wood texture from d5 lib material itself but the left 2 drawers are seen dark in preview.
i have checked for any duplicated surfaces in model but the model was perfectly 5n
any way i found the work around. and that is annoying as it shouldn’t be happening in the first place. as u see in this attached image the red boxes highlighted are previously same component. and when i exploded them and made single mesh the issue disappeared. This shouldn’t be happening. Making components is very vital while modeling. and if i had to explode components where ever this issue occurs my model will become Nightmare.
