helpppp rhino file wont open. is it because te file is too big? its stuck on 47 percent all the time.
D5 Render Version:
**Graphics Card:**GeForce RTX™ 3080
Driver Version:
Issue Description: stuck on loading at 47
Hello, you opened the 3dm file in D5 directly, right? Maybe you can send the model file to us for testing if possible, we can see whether it consumes large resources to cause the problem.
Second, please try using D5-Rhino live sync converter to see whether it can be imported into D5. Workflow | D5 Converter-Rhino - Workflow / Rhino - D5 RENDER FORUM
Any updates would be appreciated.
Regards,
Oliver
ive tried both importing them and using the d5 live sync. both to no success. The files does have 200mb embedded materials files. could this be the problem?
