Revit Textures and Colors fail to load into D5
D5 Render Version: 3.0.1.0683
Graphics Card: NVIDIA GeForce RTX 3060
Driver Version: NVIDIA 32.0.15.9186
Issue Description: Many, but not all textures and colors from the Revit model fail to load into D5
Hi there,
I apologize for the inconvenience. Can you provide us with more information regarding the nature of these textures?
  • Are they from Revit’s Library?
  • Were they imported as from your downloads? Or are they from Corona?
  • How about your Revit Plug-in version?
I had the same problem with textures.
In my case, I found that the “long path names” option was enabled in the Windows settings.
This was causing texture exports to fail in both D5 Render and other programs.
I disabled this setting, and almost everything started working fine again.
In the specific case of Revit, I used the PyRevit program with the “Relink Textures” function, located in the Edit menu. With this function, I then exported without problems, and the textures worked. This was only necessary for old files saved before disabling the Windows setting. Everything works fine with new files.
long path names and PyRevit fix my problem. very thanks!
