revit problem
**D5 Render Version:3.0.1
**Graphics Card: rtx 3060 ti
**Driver Version:32.0.15.9186
**Issue Description: If you turn on the d5 new window and sink in the revit, it tells you to update the d5, and if you turn off the new window and sink in, it tells you to select the pass. However, d5 is already the latest version, and even if you select a pass, the window will repeat asking you to select the pass again.
Hi @taewon34
I apologize for the inconvenience. Can you please send us a screenshot of the error prompt that appears?
