Hi i love D5 Render I just have a question.
It is okay if my render in 8k takes 20-30 minutes? I’ve seen people rendering in only 5-10 minutes. it’s there anything I could do to speed up my rendering time and increase the fps? I have another proyect that is taking me about 1-2 hours to render.
I work on a Laptop this are the spec.
Dell G series G15 5515 AMD Ryzen 7 5800H Nvidia GeForce RTX 3060, GDDR6 6 GB 512GB SSD 16GB Ram.
Im about to buy the pro version.
https://drive.google.com/drive/folders/1dRNusFjm0q9hhoLdjpE-dDwQ2gaf-G2l?usp=sharing
Hi there,
Thank you for reaching out.
The rendering speed is related to the complexity of the scene (specifically the number of faces of the model, the number of plants and lights, the accuracy of the mapping, etc.).The more complex the scene is, the higher the video memory and memory usage will be and the longer the rendering time will be.It is advisable to hide some unneeded resources in the scene when editing the scene or rendering to improve fps.
Secondly, 8k images have a higher resolution and take relatively more time.
In addition, laptop with 6GB of video memory and 16GB of RAM has a relatively small power supply, so it will result in slightly slower rendering.
You can refer to D5 Benchmark Tool and compare rendering time with hardware of the same configuration to see if the rendering speed is within the normal range.
We will also continue to optimise the carrying capacity and improve the rendering speed in future releases, so stay tuned.
Regards,
Lia
