Rendered image exposure mismatch
Rendered image exposure mismatch compared to D5 viewport while using auto-exposure and Sky Background power smaller than Sun Power like Sun=600 Sky=150
Hi @Smolak
This is expected. Minimal differences between the Preview Screen and the final render are anticipated, as the final render provides the most accurate calculation of the settings you have configured in D5 Render.
To achieve the closest possible outcome to the final render, you can use Render Preview (F4).
Some unnatural cases that need further testing through file collection tend to exhibit this level of difference between the viewport and the final render.
Hi @Clov, yes it was compared using render preview in viewport. This is noticeable only using high lighting strength and exposure compensation. Default light like 15 works fine.
