Remove Material Asset From Model Object
D5 Render 2.5 pro:
Graphics 3080:
Driver Version:
Issue After copying a material from another object and applying to a different object, how do I reset the object back to its original material? :
Hi mate, You have to change the material ID in the modeling software then reset or replace from local to recover the original material.
The current logic for synchronising materials via direct read [update model] is that:
  1. Once imported, all materials are no longer modified by the material parameters in the modeling software.
  2. Only the material with the new material name will be re-synced as a new material, i.e. the updated model will only recognize the new material name.
So again, The most efficient way to revert to a material in the modeling software is to rename your material in the modeling software and then update/re-sync the model.
Thanks. That is what I needed up doing. It would be a good feature to be able to reset back to the original material. Regards. Gregg
Thank you for your advice
