D5 Render Version: 2.5.0.0310
Graphics Card: 4090
Driver Version: 536.99
Issue Description: im geting reloading Failed when i open a project that other person do and send to me, that i need to do updates
Hi mate, please try to replace from local and manually select the files, the reload can only be used with the same-named flies in the same path.
Worked but for some reason, the model dislocate like 1m from original place…
Thank you for your update, did you move it or change the central point of the axis?
