Release notes | D5 Sync for Blender
Ver. 0.9.1.0051
Release date: 20241024
New
  1. Supports Blender 4.2
  2. Supports camera animations
  3. Supports linking external Blender files (File > Link)
  4. Supports curves, surfaces, and text objects
  5. Supports modifiers on curves, surfaces, and text objects, including geometry nodes
  6. Supports instantiation of empties for curves, surfaces, and text objects
Optimization
  1. Supports synchronizing IES lights and light colors to D5
  2. Custom light groups and light names in D5 will be preserved when synchronizing again
Fixes
  1. Fixed the delay in Blender when enabling viewport sync
  2. Resolved an issue where empty material slots in synced objects rendered the plugin unusable
Known Issues
  1. Collections in linked (File > Link) external Blender files are not supported for sync/export
  2. Materials of linked models are not supported for baking
  3. Models instantiated from empties in linked external files are not supported for sync/export
  4. Simple line models are not supported
  5. Materials of curves, surfaces, and text objects are not supported for baking; convert to mesh for baking
  6. Models with geometry node modifiers are not supported for baking materials
Ver. 0.9.0.0102
Release date: 20240709
New
  • Compatible with Blender 4.1
  • Supports more Geometry Nodes from Blender 3.4 to 4.1
  • Supports more Modifier operations from Blender 3.4 to 4.1
Optimization
  • Increased sync speed
  • Increased sync speed for Geometry Nodes
  • Increased speed for single texture baking
Fixes
  • Fixed synchronization and material issues for models duplicated using Alt+D
Known Issues
  • Operational delays in Blender when view synchronization is enabled
  • In linked mode, the operation of un-hiding objects cannot be synchronized to D5 Render. To ensure proper synchronization, it is recommended to move the object after unhiding it before syncing
  • Currently not supports Geometry Nodes with initial data types set to curves, including curve to mesh
  • Materials of certain geometry nodes are temporarily unsupported for synchronization and baking
Ver. 0.8.0.0096
Release date: 20240125
New
  • Compatible with Blender 4.0
  • Exported .d5a files support thumbnails
Optimisation
  • Improved launch speed for non-first-time Blender starts after installation
Fixes
  • Fixed normal issue that some models synced into D5 being blackened or greyed in colour
  • Fixed the issue of texture anomaly when exporting .d5a to D5 after baking the same material for the same object with different resolutions.
  • Fixed the size issue of Blender 3.5 models synced to D5.
  • Fixed the issue that models were not synced to D5 after the end of sync in some scenes.
Known issues
  • Curve to Mesh node sync is not supported yet.
  • Hiding objects does not trigger incremental sync, it is recommended to use full sync.
  • If the sync is abnormal after using a modifier, it is recommended to apply the modifier before syncing.
  • When you use Alt+D or other methods to associate copied objects with sync errors, it is recommended that you select the model first, click blender Object-Relations-Make Single User-Object&Data&Materials, and then sync.
Ver. 0.8.0.0039
Release date: 20230731
New
  • Support Blender 3.6
Fixes
  • Fixed the issue where some scenes could not be synchronized to D5
Known Issues
  • When using Blender 3.6, the synchronization speed of the D5 plugin is about 3 times slower than other versions.
Ver.0.7.0.0134
Release date: 20230221
New
  1. Support Blender 3.4
  2. Support mapping the cloth material template in D5 Render
  3. Support D5 Render 2.4
  4. Optimized baking algorithm
Fixes
  1. Auto-UV baking error
  2. Material failed to bake when the file name has characters unsupported by Windows OS
  3. Wrong size of sync-ed rectangular lights.
  4. Material failed to bake when some models were deleted.
Ver.0.7.0.0007
Release date: 20221108
New
  1. Blender 2.93LTS/3.0/3.1/3.2/3.3LTS supported
  2. One-click installer
  3. New UI and interactive experience
  4. Supported materials: Principled BSDF、Glass BSDF、Emission、Diffuse BSDF.
  5. Incremental synchronization of models, materials, lights, and cameras.
  6. Live sync of the viewports.
  7. Export certain selected objects.
  8. Supported texture formats: .png/.jpg/.bmp/.jpeg/.tiff/.tif/.tga.
  9. Ignore unsupported nodes and sync textures directly.
Currently unsupported:
  1. Curves. Please convert curves into meshes then start sync. (Select the model-Object-Convert-Mesh)
  2. Geometry Nodes, curves of Cycles, Modifiers with multiple frames. (only one frame can be synchronized)
  3. Rotation in UV mapping. (Only X and Y axes of Location and Scale in Blender can be synchronized)
  4. Models or lights from instancing empties.
  5. Displacement nodes. (We can use modifiers to make displacement effects instead)
  6. Node Groups. (It is recommended to link principled BSDF and then bake them)
  7. Copies of baked models need to be baked again before sync.
  8. Shape keys.
Known issue
  1. The UI language change will not take effect until Blender reboots.
  2. If the textures are baked totally black, please send the Blender file to support@d5techs.com.
  3. Hiding or unhiding objects cannot activate the Sync button.
