Reflections of trees incorrect
**D5 Render Version:2.3.2.0929
**Graphics Card:2078
**Issue Description:Reflections Incorrect
Screenshots/Videos Description: Working in the layout window the reflections of the trees look as expected. On the final render though the leaves in the reflections look triangulated
Working screen:
Finished Render:
Dismiss the white speckles on the model, the transfer from OBJ to SKP had a few wee issues :face_with_raised_eyebrow:
Hi! We did not reproduce the issue.
Could you please send us a sample D5 scene to rubyliu1107@gmail.com for troubleshooting?
Hi Yah Ruby, Thanks for the reply, I’ll send a WeTransfer request to your email :smile:
Anything obvious Ruby, ended up finishing that project in Twinmotion.
Thanks for the update!
We will check your file when we are back to the office. If the WeTransfer file is overdue, then I will let you know.
I downloaded the file you sent. We produced a build before to repair the issue related to the first grass template and this build can also fix the issue you confronted. Please check this post: [Hot issue] Grass and plants disappear from a distance.
Hi Yah Ruby, Sorry I have applied the Fusion Build as per instructions, restarted D5 Render ran another final render and the same problem exists :frowning:
