hi
can Radeon RX *580 GAMING X 8G work with d5
thanks
Hello, for now, it cannot pass the hardware test, but you can bypass the hardware test then run D5 with it.
Bypass D5 Benchmark test | Use D5 Render with Titan X - Get Help / How to - D5 RENDER FORUM
(The performance may not be very good since it does not belong to recommended GPU)
I would recommend this card to anyone trying to game at 60 FPS that doesn’t want to go overboard. sign language alphabet 120+ fps on rainbow 6 siege. It features 2304 shading units, 144 texture mapping units, and 32 ROPs. AMD has paired 8 GB GDDR5 memory with the Radeon RX 580, which are connected using a 256-bit memory interface. The GPU is operating at a frequency of 1257 MHz, which can be boosted up to 1340 MHz, memory is running at 2000 MHz 8 Gbps effective.
Hello. I have two RX580s installed ¿Will they work with the latest version of the d5?
Sorry for my English, I’m using Google Translate.
Hi there @arq.filippetti
Our system requirements are as follows:
- Minimum requirement: Nvidia GTX 1060, Intel Arc 3, AMD RX 6400
If you’re GPU is below RX 6400, then it can’t run D5 Render, and we don’t recommend bypassing the Hardware Test right now. - Recommended Requirements: Nvidia RTX 3060 (Ti)
- Optimal Requirements: Nvidia RTX 3090
if i want to buy a new laptop what are the best requirements if i want to render pictures and videos in 4K?
