Program needs admin to run
**D5 Render Version:**2.8.0
Hi, I’ve recently installed 2.8.0 on users machines in a citrix environment and each time it runs, I get the attached admin prompt.
If I click no, it still opens but would like to remove this as users don’t have admin access.
Thanks
Hello, is your installation path C:\Program Files\D5 Render? You need administrator privileges to run D5 if you want to install it under this path.
It was installed as an administrator to that location.
So are you saying it needs admin to run the program every time after installation?
The previous 2.5 we tested didn’t do this.
