Problems with gpu
Hi, i got a rx6800xt saphire nitro, when i enter on the file wich i want to renderize, the gpu consumes less watts than it should, arround 120w, when the correct onsume is arround the 280w. I already try the gpu on other programs and works correctly. The problem is that when i try to move on the scene or when i try to renderize, everything is slow and take too much time
Hi @facundosebastiancomi
I apologize for the inconvenience. Can you please send us a screenshot of the following:
Please try the following:
  1. In your AMD Software, AMD Radeon Software:
  • Right-click on your desktop and open AMD Radeon Software.
  • Go to the Performance tab and then Tuning.
  • Set the Power Limit to its maximum value.
  • You may also want to ensure that you are running the latest version of your drivers.
  1. Windows Power Plan:
  • Go to Control Panel > Hardware and Sound > Power Options.
  • Select the High Performance or Ultimate Performance plan.
Let me know if there are any differences in performance.
