Same problem, same graphic card, same D5 version and same driver version. Cars and Individuals models are missing. (And I had also “pro” problem, solved by simple login again)
@a.drexler@cokealcaide hi mate, sorry for that, for now you can download those assets again from the D5 assets library, then reopen this scene or update in this scene, and those assets will be successfully updated.
Or you can wait for our fix. We are working on fixing this issue asap, and will let you know when the problem is solved.
hi mate, ok, we will release an update to fix the updating issue about one hour later.
To confirm, the missing objects you meant are assets on path tools, right?
