Problems with 2.5
**D5 Render Version:2.5.2.0.0309
**Graphics Card: RTX 3090
**Driver Version: 31.0.15.3667
Hello D5 team,
unfortunately my scene from 2.4 is missing cars or
there are messages regarding PRO.
See the attached picture.
Do I now have to reposition the library parts in question?
Bye
Andreas
OK, the message regarding PRO has been dealt with!
Strangely enough, I wasn’t logged in!
But the cars are still missing.
Same problem, same graphic card, same D5 version and same driver version. Cars and Individuals models are missing. (And I had also “pro” problem, solved by simple login again)
@a.drexler @cokealcaide hi mate, sorry for that, for now you can download those assets again from the D5 assets library, then reopen this scene or update in this scene, and those assets will be successfully updated.
Or you can wait for our fix. We are working on fixing this issue asap, and will let you know when the problem is solved.
Objects are also missing from a project that is important to me.
Among others, wagon 01 again.
The other objects can be seen in the attached picture.
Hello Oliver,
thanks for the info.
I guess I will wait, as some of the missing objects have an animation path.
Bye
Andreas
hi mate, ok, we will release an update to fix the updating issue about one hour later.
To confirm, the missing objects you meant are assets on path tools, right?
Hi @a.drexler @cokealcaide The update fix is released, please update and let us know whether the problem is fixed, thanks in advance!
Good morning Oliver,
how do I get the Fix?
Bye
Andreas
3 posts were split to a new topic: 2.5 cannot launch
Hi mate, open D5 then you can get the update.
Problems fixed, now all previously missing objects are loaded.
Super!
Thanks for the quick response to the D5 team.
Bye
Andreas
