Problems in D5Render since last update 2.4.2.1061
D5render lags even in smooth preview quality when a project object with a high polygon count appears in the viewport.
It occasionally lags even when all objects are hidden.
The mouse movement in fly mode is strange and slow.
When some library objects (people) are added to a project, they appear 10 times larger.
Furthermore, due to the high polygon count, some objects (vegetation) in the library cause the program to lag when used.
Another vexing issue is that sometimes the object tab remains blocked, so if I scroll down or up, it returns to the blocked position and becomes unusable.
Hi mate, does this problem happen to a specific scene file with the object with high polygon count? Sorry that we cannot reproduce the issue regarding the plant and character assets, could you send the model file and D5 scene file folder to support@d5techs.com for testing?
Hi! I opened older D5render projects that used to work properly but are now lagging. I’ll email you the D5 scene.
