D5 Render Version: 2.8.0.0471 Graphics Card: Nvidia RTX 4070 8 Gb Driver Version: 561.09 Issue Description:
Al ejecutar el programa me sale el siguiente aviso: Error al iniciar el programa. Error de entorno del sistema. Por favor sigue el tutorial para resolver el problema, o contacta con el servicio al cliente.
Y no puedo ejecutar nada más. Se queda pensando y no puedo abrir ninguna escena. Screenshots/Videos Description:
Hi there, I’m sorry for the incovenience this issue has caused you. There are several possible factors that caused this issue, which are usually linked to the DLL files. Can you provide the following information? Please refer to the images below.
There can be several different reasons for errors related to DLL files. For example, malware corruption on the computer, damaged Windows registry, d3d12.dll file being deleted or misplaced, application errors, etc.
Possible Solutions:
Try a clean installation of the graphics card driver and change a path to install D5 Render
