**D5 Render Version:**2.01
**Graphics Card:**3080 TI
Driver Version:
Issue Description:
Hola, estuve he estado trabajando una escena que se modelo principalmente en revit, luego la exporte como link a 3dmax, y luego con el converter de D5, hice algunos ajustes al modelo y luego toda la geometria de mi topografia perdio mucha calidad y no se ve suave.
Hello Sjimenez1.
I saw your message last night, but for problems now I can answer you, this quality problem does not depend on D5 but on the connection between the graphics program and the D5 rendering program.
You can solve it in various ways, increasing the faces of the terrain topography, then you will also increase the fails value to export to D5, I don’t know if it suits you, you would have problems managing the job. Or export to SKP which has the function of softening the ground, and this D5 can handle and see with ease.
I hope I have helped you
Muchas gracias, lo solucione importando de nuevo pero desde revit, pronto subiré el resultado
