PNG flickering
Hi All,
I’m playing around with D5, as I want to switch from Lumion, but I get flickering *.png ‘decalls’. I don’t see a way to reduce that like in Lumion (flickering reduction). This is very essential for me as I’m a exhibition and interior designer. Can someone please help me with this? Thanks in advance…thanks. Pepijn
There are two overlapping polygons.
You can solve this in two ways:
1- D5: if you’re lucky, select (press i) the material you don’t care about and make it invisible.
2- sw 3d: simpler method. Increase the distance between the two polygons. Save in fbx and import in D5
Thanks Paperless, but often, when I place the decal in front of the polygon it gives a shadow. It would be great if you can “stack” materials like you can in Lumion.
Hello, if it gives a shadow, you could check this option to solve the problem:
THanks! Will try that!
