**D5 Render Version:**2.4.1.1045
**Graphics Card:**RTX 3060 Ti
**Driver Version:**531.29 Latest Drivers
**Issue Description:**Pc Restart While 2k or 4k Rendering
Most probably CPU overloading, monitor the cpu temperature during rendering if it goes beyond 95 98 C then thermal throttling can cause such restart just to protect your system.
thnks for you reply but i already chekcd gpu temperature stays normal 60 65 but pc goin restart again nd again ![]()
Hello, you can try to update the latest graphics card studio driver (531.41), using a previous card driver will cause D5 to crash. At the same time, you can check the hardware parameters such as memory, if the power supply is insufficient, it will also cause problems. If these still don’t solve the problem, please contact me!
