PC reset after educational license request
Hello, I had to reset my PC after requesting the education license. It is exactly the same device.
What should I do?
Hi @lucien.poupard
Thank you for reaching out. In D5 Render 3.0, you should be able to unbind your device directly from your MySpace page. Please log in to your Launcher, click on your email, open your My Space page, and unbind the previous device entry. You can then log in again to your current setup.
Please also note that device unbinding is limited to once per year, so kindly proceed with caution before confirming the unbind. If you encounter any issues while doing this, feel free to let me know.
Hello, I have same problem I already sent and email. Thank you for help in advance.
Hi @jaromir.cervenka
What version of D5 are you using? In D5 Render 3.0, you should be able to unbind your device directly from your MySpace page.
I did the unbind and I am pretty sure the device name was the pc I was using but while login it said use the bound device… I applied for new educational licence is there way to get it faster then last time?
I bought the pro for one month I hope you will not change it with the educational :smiley: atleast for the month
I’ve checked your account and can confirm that you subscribed to the monthly Pro plan but canceled it shortly after.
Please note that your subscription will remain valid until the end of the paid period. Since it has been canceled, it will simply not renew for the next billing cycle. There will be no changes to your current plan during this active month. Thank you
