D5 Render Version:2.7.1.0.463**
Graphics Card:RTX 4090**
Driver Version:552.22**
Issue Description: outline rendering discrepency
it as you can see on the rendered view “Outline” you can see triangulation lines as well as lines which appear but which do not even exist in the modeling
Sorry for your issue. Did it occur in all scene-files or just this specific scene-file? What resolution are you rendering out? Is this a problem for all resolutions? If it’s just this scene file, can you send us the scene file to check it out? You can DM me directly or send the scene file (The entire folder where the .drs file is located) to support@d5techs.com with the briefly describe. We will check it. Any update will be appreciated.
scene sent + output renders
the inconsistencies become visible when the renders are done at higher resolution above 4k i think.
It seems to me that I have already seen this type of error (triangualtion or extrapolation of lines) in other scenes.
thanks for support
Thanks for your information. May I ask where did you send this scene file? I will check it from my end.
Sorry, I seem to be unable to click on it, there is no jump link.
Ha sorry sent by mail @ support@d5techs.com
Sure. I will notice the mail.
I confirm that the same issue is happening DLSS and SR off
I didn’t find your scene file in support@d5techs.com mailbox. Please take a look at the private message I sent you.
just re-sent the link via PM
thanks
Received! Thanks a lot. I will check from my end and get back to you. Thanks for your cooperation and patience.
