D5 Render Version: 2.0 Graphics Card: RTX 2060 Driver Version: 472.12 Studio Version
Issue Description:
No antialias and and poor noise reduction in the Preview Window or when Rendering a Final Image. These issues occurs in the version 2.0 of the software (for new and old projects)
I have tryed:
1.Update Driveres to the last version
2. Install a Clean version of the software (no update)
Hello, what resolution it is? Could you show us a photo of 1.9, compared with 2.0, and a same scene with same parameters?
Turning on DLSS will increase the antialiasing effect, also, we optimized the noise reduction in 2.0. We will test the latest video driver, and hope you could share with us the above info we need.
No bro, normally the file from autoupdate is the same as clean install. Here we are looking into the antialiasing and noise reduction effect, you can have a try on D5 2.0, how is the antialiasing effect?
I Fixit.
Aparently the problem was in some leftovers of the previous version (1.9), so, i deleted these files in the APPPDATA and instaled a clean version of the 2.0 version. It works.
Hello, before doing a clean reinstall, you could migrate your local library files first. Preference - User Manual (d5render.com)
Also you could try upgrading your video driver first.
If the problem remains, then you could try reinstalling D5 Render( backup your important project files first)
yes, the 2.0 update normally should not have this kind of problem. To turn on/off DLSS, you can open a scene then click Menu button on the top-left-> Nvidia DLSS, check or uncheck it.
Thank you. Found the button just before I saw your post. It seems to help the preview turning it on actually. Not sure it has much to so with output render.
