**D5 Render Version:latest
**Graphics Card:RTX A5500 Driver Version:
**Issue Description:Failed to load some resources Screenshots/Videos Description:
Just got this error. I have given rectangle lights everywhere instead of point lights. I was in the impression that rec lights are less power hungry to use. Also its just insidental lighting in the scene. Like street lights etc. Building balcony lights etc etc.
Hi, thanks for the feedback!
This light limit popup is possible, the current limit of the four artificial light sources in D5 is 1024, exceeding this value will prompt this error popup (it has nothing to with which artificial light source).
If you open the “Show Statistics” function, it will show you the number of artificial lights in the scene (including the unused lights).
If the number of artificial lights in the scene does not exceed 1024 when this error is displayed, please contact us again to take a look.
Currently, the maximum number of artificial and spontaneous lights in a viewport is 1024.
If this limit is exceeded, it is recommended to manage the lights in each scene shot using layers or groups, and to hide or remove unnecessary lights for the rendered shots.
