**D5 Render Version:3.0, 3.01
**Graphics Card:4090
**Driver Version:591.74 studio
**Issue Description:After updating to 3.0, navigation in the viewport did not work correctly, regardless of the set movement speed, it moves the same and acceleration and deceleration with shift and spacebar do not work. Is this how it should be? Or can you recommend how to fix it?
Rolling back to version 2.11 helped, but I want to use the latest version.
Hi @avi-dm
Thanks for reporting this. To better understand the navigation issue, could you please provide a short screen recording showing how the viewport movement behaves, including the movement speed setting and how Shift and Spacebar respond? Also, please confirm whether this happens in all projects or only a specific file? Thanks you
- Navigation speed with a value of 1, that is, it should move very slowly,
- Navigation speed with a value of 100, that is, it should move very fast, 100 times faster than the first mode,
- Navigation speed with a value of 5 and the shift key held down, it should move fast enough,
- The navigation speed with a value of 5 and the space bar held down should move slowly enough.
In fact, all modes have the same speed of movement. This happens in all projects.
https://disk.360.yandex.ru/i/uPxcjg8bROeJEg
Hi @avi-dm
Thank you very much for the video and for the detailed clarification.
I tested all the scenarios you mentioned on my end (different navigation speed values and using the Shift and Space keys), and everything appears to be working normally. Unfortunately, I wasn’t able to reproduce the issue.
Based on your video, I can see that the navigation movement speed remains the same regardless of the value or modifier used, which is not the expected behavior.
To help us investigate this further, please collect your D5 log files and send them to support@d5techs.com. Kindly tag me in the email and include a link to this forum post for reference. Thank you.
