My Pro session disconnects when rendering
**D5 Render Version:**3.0.1
**Graphics Card:**Invidia 3070
Driver Version:
Issue Description: trato de renderizar por lote y se me desconecta la cuenta haciendo que los archivos se exporten con la censura de los bloques pro, nunca me habia pasado algo asi
Hi @abcdesignve
I apologize for the inconvenience. Is this happening frequently?
In the rendering queue, the current account’s Pro status is checked for each project. Previously, if a network disconnection was detected even once, the resulting images would be watermarked. With the recent updates (2.10), normal short-term network fluctuations should no longer result in watermarked issues for users.
This issue only occurs:
  • Major Network fluctuation/disconnection
  • Someone has logged in to your account via a different device.
Please try the following:
  • Try to connect to a different network and check if this results in frequent disconnection. You may try the exact same process (batch rendering), or simply an individual render should suffice.
  • If you have activated a VPN, please try to disable it.
