Muros que parpadean
Hola, las texturas de los muros están parpadeando, saben porque? Gracias!
Hi mate, here are some possibilities:
  1. The faces are overlayed in your modeling software or some objects hidden you don’t find. (most possible)
  2. UV map is not correct, please make sure the scale of texture in your modeling software and D5 is suitable.
  3. Lighting issues.
If it still happens after revising. please screenshot it or describe it more in detail for us.
Muchas gracias
Cuando hago el link del archivo de sketchup a D5 la pantalla se pone en negro, me deja ver los assets de D5 pero no me deja ver ni un solo elemento de sketchup
Hi there, you can check if it is because the model in SketchUp is too far away from the world coordinates. If it is, the model can’t be seen.
Thanks a lot!!
Saludos!
