Model rotates between Revit to D5
D5 Version: v2.3
Graphics Card: RTX 3080
Driver 516.94:
I have an issue with the way models are orientated when D5 is started from from Revit.
After the model has been brought into D5, it seems the model have been rotated -90 degrees. This is evident when selecting Camera>View>Top. The two images attached show the behaviour.
The first image shows the model set at True North in revit and in ‘Top’ view. The second image shows the camera set to ‘Top’ view in D5. It has rotated.
Image 1 from Revit 2020 - Model set to true north in revit and view set to ‘Top’
Image 2 from D5 - Model set to ‘Top’
Is this expected beaviour or am I missing something? If I want a shadow study, I then have to set up the ‘North Offset’ …not ideal.
Regards,
Jo
Hi! This is due to the preset coordinate settings in Revit and D5. The coordinates in Revit and D5 are opposite, namely one is left-hand coordinates while the other is right-hand. So for now, you need to adjust the angle manually and we will optimize it in the future.
is this solved now ? we have multiple files over different softwares like revit rhino and sketchup that i’d like to combine, the revit rotates and moves while combining in D5
Kind regards
Hi @ict
Hi there,
Revit’s coordinate system is inverse to the coordinates of the other modeling software thus, when being placed in D5 Render, the model is rotated. As a workaround, you may need to manually rotate the model to your desired position.
Additionally, There are also articles and even dissertations that explain Revit’s Shared Coordinates in detail.
  • If you are interested you can check Paul F. Aubin’s The Revit Theory of Relativity: Understanding Shared Coordinates
hi, thanks for the response, i understand that, but however when you’re combining multiple files from different program like rhino, sketchup and revit, its very unhandy since you’re not able to get your models from different programs to fall in to place, a proper align tool where you can align surface to surface would be handy as a temporary solution atleast when you want to posistion manually. but in the longer run i would like to see this as a feature implemented, where you can combine all the programs into the D5, could you put it in your next version ?
Kind regards
Hi @ict
Thanks for your feedback, we will forward your suggestion to our team. Although we cannot guarantee that this request will be realized immediately in the next version, rest assured, it will be considered.
Please address this issue. It has been disruptive to our workflow as well.
As a work around, we have been setting up project north at +90 degrees when synching from Revit. So far, this has aligned successfully with our unrotated models coming from Rhino and Sketchup.
The position of the synched Revit model doesn’t align when manually rotating it in D5 Render.
Hi @iplumb
Sorry for the inconvenience. Could you please provide a screenshot or a short screen recording showing how the Revit model appears in D5 Render after syncing and manual rotation? Thank you
Do I have to rotate the north offset in ever single view separately or is there a way to to set it globally?
The problem exists, and in ArchiCAD its +90 degree.
