Missing Asset "WaterDripping 12.d5a" After Upgrading to D5 Render 2.11.0
D5 Render Version: 2.11.0
**Graphics Card:**5090
Driver Version:
Issue Description:
Dear D5 Render Support Team,
I hope you’re doing well.
I recently noticed that after upgrading to D5 Render version 2.11.0, one of the assets from the Free Version seems to be missing. The asset is located under:
Assets > Particle
and the name of the missing asset is:
I have previously used this asset in one of my ongoing projects while I was working with version 2.10. However, after updating to version 2.11.0, I can no longer find this asset in the library, which is now causing an issue in my current project.
I kindly request you to look into this and consider re-adding the WaterDripping 12.d5a asset to the current version (if it has been removed unintentionally), or please guide me on how I can retrieve or re-import this asset into the updated version.
Looking forward to your response.
Hi @sanjuky86
Thanks for bringing this issue to our attention. I have reported this problem to our team, and we’ll be fixing it as soon as possible.
Hi @sanjuky86
We have restored it. Please check thank you.
Thank you very much for resolving the issue regarding the missing asset WaterDripping 12.d5a in version 2.11.0.
I truly appreciate your support and quick response—it helped me continue working on my project without further delays.
Keep up the great work, and thanks again for your help!
No problem~ Thank you too for reporting!
