Midday 02 blurred
**D5 Render Version: 2.5…
**Graphics Card: RTX 3090
Hello all,
the HDRI image Midday 02 is very blurry even in the exported image.
That can’t be right!
See the attached image.
Can only be a setting thing.
However, I do not find.
I hope for your support.
Bye
Andreas
Hi mate, is this image 4k? Did you use the Depth of Field or focal length with big parameters?
Thanks for the feedback and the attached image. I also tested this HDRI in 8K size and found it was a little blurred. But it’s also common for offline render engines to some extent. Will fix it asap. Sorry for the inconvenience.
Thanks, Did you test this HDRI with 8K? also usable?
The upper message I have not written!!!
Someone just changed my text!
That’s not possible!
Who was that?
Why?
How is that possible?
I hope this does not repeat itself again!
Here is my original message!
Guten Morgen Bruce,
das Bild ist 4K. Ich habe keine Schärfentiefe verwendet.
Etwas Unschärfe wäre in Ordnung, aber so wie es derzeit ist, ist es nicht verwendbar.
Ein Ersatz dieses HDRI ist auf jeden Fall erforderlich.
Tschüss
Andreas
Sorry, maybe the text is overwritten due to some reasons. Also, I have reported the problem we will fix it soon.
OK, thanks for the message!
