Materials modified in D5 are reset when opening the file on another PC (Normal in previous versions)
D5 Render Version: 3.1.1
Graphics Card: RTX 3060
Driver Version: 32.0.15.6094
Issue Description:
I am working on the same file from two different locations: my home and my office.
Issue scenario:
  1. Sync SketchUp with D5.
  2. Modify the materials in D5.
  3. Save the file.
  4. Download and open the file again at another location (office).
  5. Sync SketchUp with D5 again.
  6. → At this point, D5 follows the SketchUp material settings, and the material changes previously made in D5 are reset to the SketchUp values.
Current workaround:
To prevent the materials from being reset, I have to repeat the following process for each material:
  1. Rename the material in SketchUp.
  2. Re-sync with D5.
  3. Save the texture modified in D5 locally.
  4. Reapply the local texture to the material in D5 using the Brush tool.
→ This keeps the material settings consistent when opening the file on either PC. However, having to repeat these steps individually for every material is very tedious.
Important: This reset behavior did not occur in previous versions. It seemed to work normally until last year, but the issue started after updating to the latest version, so I suspect this may be a regression issue.
According to the documentation, once a parameter is changed in D5, the D5 value should take priority and should not be overwritten by SketchUp. However, in practice, the changes made in D5 are not preserved whenever the file is reopened and synchronized.
Please confirm:
  1. Is this a known regression issue in the latest version?
  2. Is there a way to preserve material modifications made in D5 across different PCs without having to repeatedly save and reapply the local textures using the Brush tool?
  3. Which version did not have this issue? (A rollback may be necessary if applicable.)
  2. Modify a material in D5 and save.
  3. Open the file on another PC and sync again.
  4. → D5 follows the SketchUp material settings, causing the material modifications made in D5 to be reset.
Hi @whf0914
I’ve translated your post to help everyone understand your thoughts better. To make our conversation smoother throughout this forum thread, it might be beneficial to use a translator. Thank you.
We cannot replicate this issue; every time I modify a material in a certain file → then open it on another device → then sync it to its SKP Model → the materials are retained.
Just to confirm
  • This is not a known regression or issue, although this is a common problem among users with different devices who are using a shared path or cloud storage
We would also like to know more regarding your setup:
  • Please save the file to your local C or D drive after downloading it on your device.
Note: If you’re not on D5 Teams, it is advisable to use your Shared Path or Cloud storage to archive these files. It’s recommended to compress the files into a zip format before placing them in these storage locations. When accessing the files on your preferred device, make sure to transfer the zipped file to your local C or D drive before unzipping or opening it. This recommendation also applies to your 3D model files.
  • Check your D5 LiveSync version. Since you’re using SKP, it is best to use D5 Lite as the main plug-in, since it also has LiveSync capabilities.
I’m replying in English as requested.
The D5 LiveSync version I was using was the latest version.
While testing various possibilities, I found that this issue only occurs with SketchUp 2023. Specifically, when I create a D5 file in SketchUp 2023, this problem occurs.
I tested SketchUp 2025 and 2026 as well, and when creating a D5 file in these versions, the textures did not move or follow SketchUp in the same way.
Based on these tests, I suspect that the issue may be related to the SketchUp version.
For now, I was able to resolve the issue by switching to a different SketchUp version.
Thank you for your response and assistance!
