D5 Render Version: 2.3.4.0931
Graphics Card: Nvidia 3090
Driver Version: 526.98
Issue Description: Materials & light not being displayed correctly, since re-opening file
- re-opened file today and nothing looks right (see screenshot). All we have done is open our SKP file, open D5 Render via the converter in SketchUp and everything looks off.
- you’ll see from the screenshot that the materials are flat, the diffuse texture is there but everything else is missing; reflections, metalness, etc.
For example - the glass is either solid white, or if imported via SketchUp… it’s not visible at all. - When I click on a material all of the settings are correct, as they were previously, just not shown correctly in D5
- However, when you do a render, everything renders correctly, as previously setup?! (see attached)
- The render time has almost doubled too, to around 2minutes… where before, they were sub 1min.
Any help on this would be appreciated - as we have new projects waiting to be completed and we can’t work on them properly with this issue.
Thanks
