D5 Render Version: D5_Render_2.6.0.0379
Graphics Card: NVIDIA GTX 3070
Issue Description: Material set problem while replacing sketchup model
Hi. I prepared a model with sketchup and finished it with D5. i applied all the materials, i used assets, prepared scenes and i got renders without a problem. After some time, i had to work on the model again and i did some changes. Then i imported the model to D5 and replaced the old model. But i can not see any of the materials i applied earlier.
I worked on this file many times with sketchup sync, and it worked always. This time i can not use the materials that i’ve used before and whatever i tried, i couldnt get the materials. That means i have to apply all the materials again one by one and it will take a lot of time. I had the same problem with some other projects too. Thats why i am usually worried about having this problem again when i start a new work with D5.
Is there a way to save material set, and import those material set again when i replace the model? or do you have an idea why this happens, and how to fix it.
Thank you in advance
