How to make a robot’s head and arm rotate a bit in the walk thru animation?
Hi there. Can you perhaps specify which asset you are pointing out? Usually, if these assets can move their parts individually, they would have a parameters or settings tab. If they are not from the D5 Render Asset Library, I think they can be moved manually if they were imported by group or in part. Thank you.
I have the robot built in sketchup. It’s not an original D5 asset. Can I make its head and arm rotate?
Hi there. If you have imported the asset by group, rotating it manually in D5 Render should be possible. Thank you.
