Low OSS Speed & CDN Speed
I have trouble in downloading assets, the download of each asset is way too long.
My internet connection is quite good, almost 20mbps. Yet, downloading like wall materials, each need around almost 1 minute, whereas I think it shouldn’t be that long. This has been going on for at least 2 weeks and keep getting worse. Just yesterday, it wasn’t this slow. Today is the worst…
Does it have to do with Low OSS Speed & CDN Speed?
Here are the screenshots:
Screenshot 2025-03-06 091557
This is the video recording when I try to download an asset:
2025-03-06 09-24-50.zip (1.8 MB)
Hi @Cranile
I apologize for the inconvenience. Can you try to turn on “Proxy” and see if there is a difference in the download speed of the assets?
It turns out that the proxy is already on
I forgot to mention. When downloading assets, example 3 assets are downloading, D5 become irresponsive. I have to wait until those 3 assets are downloaded, then I can start working again.
Is it normal?
Hi @Cranile
Even though 3 assets are downloading, D5 should still be able to move the preview screen. May I know if this occurs in all your other files? Including small sized files? Thank you.
Yes, i’m currently opening a blank project
May I know which version you are currently using? have you tried reinstalling it?
This is the version. And no, i haven’t try reinstalling.
If I’m going to reinstall, will my downloaded assets be gone?
Screenshot 2025-03-06 104202
Hi @Cranile
As long as you have a copy of your D5 WorkSpace folder, it should not disappear. You can set it up after the reinstallation.
Additionally, have you tried connecting to another network or perhaps using a VPN? Let me know if there are any differences.
Regarding the Proxy option enabled, since it was already enabled, try disabling it if there are any differences. Can you please share:
  • Your Email Address (D5 Account)
  • Your Region
No, I haven’t try to connect to other network / using VPN. But, I’ll try disabling proxy first. I’ll also try reinstalling it as well. I will inform again after this.
As for my email address is 21a10004@student.unika.ac.id, from Indonesia
Hi @Cranile
Thanks for this information. After the reinstallation, do you mind updating to the newest 2.10 Version? After updating, try to check the CDN Speed. Let me know, thank you.
@Clov
Hi, I tried to reinstall. This is the CDN Speed…
Is it good? Also, would you mind to explain what is Proxy, Origin Speed, and CDN Speed? What does it do?
Thanks.
Hi @Cranile
Did your download speed improve? Otherwise, in your Windows Network Settings, please check if you have encryption or any software that may be limiting the download speed of the assets (There’s a possibility since Proxy was enabled by default on your end according to what you have said)
I think, today’s download speed kind of improved. Thank you for the help.
But, may I know what is the usual bandwidth needed for smooth download?
Also how long does it usually take to download 1 asset? To see, if the problem is my internet / because the asset size itself is big.
(I understand that some asset are more complicated, but maybe may I know how long is the approximate time for the most complicated asset? Is it 2 minutes? Etc?)
