D5 Render Version: 2.7
Graphics Card: RTX 2060
Driver Version:
Issue Description: Loading file d5 blocked at 5%
the other files work
Hello I have a problem on D5 my file that I closed last night does not want to open the loading stops at 5% and without any error message the program closes.
system: RTX 2060
INTEL i7 9E
32GB ram
i need it for work.
Hi, if you finished the work late last night, you will surely have the history, and perhaps if you go there you can open it. However, if the file is very large, perhaps you have placed too many objects or grass with the plug-in, it may have difficulty opening, it is better if it is an exterior and you have an expanse of land with grass with many trees you have to find another way to lighten the files.
I tried to write it in the version history but it doesn’t work my file is only 1.7gb, I don’t know if that’s a lot.
thanks, thank you for your response.
When you open D5 at the beginning you have to go to the recent ones and click on the image of your project with the right button and a drop-down menu will appear containing the history of the Files
Already done but it does the same thing the file starts to open and it closes at 5% loading.
You have inserted several things in this file, if instead you try to open the graphics file complete with everything and synchronize it with the file that does not open, see what happens. But close the other programs, so as not to tire the PC
I don’t know how to open the graphics file complete with everything and synchronize it with the file, i try to open only D5 with no other software but the same think happend clode at 5%.
Sorry, are you using to open the file connected to the cloud?
no i d’ont think. i know.
Cut the bull’s head, I hope you haven’t done much work in D5, open the graphic file you completed, rename it and synchronize with a new D5 file and work on it again, but wait with the vast areas to work on, like grass or lots of trees and people, find a texture like PBR grass and apply you will always have a nice effect.
it work.
Thanks a lot
