Ivy Generator issues
D5 Render Version:
2.6.1.0401
Graphics Card:
RTX 3090
Driver Version:
31.0.15.4601
Issue Description:
Not sure if this is a scaling issue but the ivy generator scale makes no sense. The box on the left is the default D5 geo (with no scale adjustment). The “grid” on the right is made of 8"x8" boxes. So its 88" tall! We cant seem to get any of the procedurally generated ivys to work correctly.
Hi! Scale is used to adjust the size of leaves or flowers. If you have any advice or idea with the vine, feel free to tell me.
I more meant the overall vine spread scale relative to the object size not so much the leaf/flower scale.
If we reference my initial image. The spread on the left doesn’t seem to make any sense when we take real world scale into account. The wall on the right is 7’tall and has all the same default parameters as the right side. I would have expected whats happening on the left to happen on the right. Unless i’m not using it correctly.
For the leaf/flower scale issue. The scaling seems odd as well, again when used with a real world scale. for it to look right relative to the model i ended up using .2-.3. While the slider goes all the way up to 5?
Again im not sure if its an overall scaling issue. As in the vine spread is referencing the model scale incorrectly or something else.
thanks!
Currently the generation of this vine is quite random and sometimes there are cases where the results are not ideal. You can click random to regenerate your vines.
We will also pay attention to your advice.
