Hello: I am having an issue with the grass displacement not filling in at the edges. The 2D image shows up, but not the displace
ment. Any ideas about the issue?
Hi mate, it is a known issue for close shots on grass materials, please check this topic:
And you may need to use scattered plants instead, or use scatter tool to fill in the areas with grass.
Grass Material Template using tips & edge issue - Get Help - D5 RENDER FORUM
Thanks,
Oliver
