Is there any way to get RGB running light in d5 render?
something like this but running, for a video.
Hi, you can do it this way, create the lamp with a tubular but put the material you posted in the tubular. Then you give it the characteristics of Alfa material, put the image of the posted effect in the light inputs, give it your value as you like, stronger, less strong. In this case I went to check the effect it has.
I put two images for you to understand the material settings and what I did
Then if you want the light to move you have to see a tutorial that explains it to you, just go to YouTube
I thinks multimedia template with intensity and video map can help you.
