D5 Render Version: 2
RTX 2070
Driver Version:
**Issue Description:
Hi, I am testing some interior setups and a problem occured with lighting. I am using HDRI ± rectang. light beyond the window (which is not causing the problem).
On the 1st picture there is a very weirdly shaped light from the emissive material. The lamp is round so the light should be also, but it´s acting like a box instead.
On the 2nd picture there is a weird light over the window which is not caused by the emissive lamps neither by the rectangular light which is placed behind the window ( i tried to delete it and it didn´t solve the problem, also tried switching the lamps off of course, none of it helped). I think this is some bug caused by the sun/hdri system?
If you got any ideas on how to improve I´ll be glad. Thank you.
