Imported fbx not loaded in saved file
D5 Render Version: 1.9
Graphics Card: RTX 2080
Driver Version:
When i saved a imported fbx and close D5, after reopen en loading the project the file is stored in the browser left but not loaded directly, so the stored scenes are empty.
Solution for this?
Hello, what kind of FBX file, is it animated? Also, the file is on a local place or online place(NAS), we do not support storing in online place yet.
It was indeed a NAS problem, exporting the fbx to the local disk resolved the problem
We will support NAS in the next version :laughing:
OK! Thanks for the answer
Does this mean NAS support is live with the 2.0 release of D5?
Yes, you can put your file in NAS, then see the result.
I still suggest you backup files in a local place first.
Did a project in version 2, import fbx stored on the NAS, saved, seems to work, but next day want to adapt some things and all i see is a empty scene, the fbx seems located in the import section but i don’t see it… have to do everything from scrats again, not nice…
Hello, now we have two limitations when using NAS:
we need to make sure your NAS has been mapped to a local drive:
Map a network drive in Windows 10 (microsoft.com) 1
make sure the path you use when saving files is a local path format, like F:\d5render\xxx
do not use an online path like //d5render/xxx/ or: OneDrive - Personal, etc.
I think if you do them both, then the problem will be solved. Also, we will optimize this in the future.
Have a nice day!
