Image size keeps changing?
The render image setting (size, file format) keeps changing every time I use D5 for other projects. Is there a way for each project file to remember the last render image setting used for that specific project?
Good advice, I have shared this request with the team.
Hello ı found this topic via search bar. I am generally using 1920x1080 but for each project and for all frame i have to type these resulation many times. And I aware sometimes it is not saving the resulation when i add scene and update it. Thanks
Hi @cagriokur
At the moment, D5 Render does not support a global default resolution setting (such as always saving 1920 × 1080). This means the resolution needs to be entered manually each time you create a new project. Unfortunately, this feature is not supported yet .
As a workaround, you can reduce repetitive input by:
  • Using “Apply to All” in the render settings to apply the same resolution to all scenes.
  • Selecting multiple scenes at once and setting the resolution in one step.
You may find this similar thread on Forum helpful: Why there is no Option to Save Default Image Settings (Format & Resolution)?
Hello thanks a lot for your response. Apply to all options works for the enviroment and effects. (version 2.11.1 ). I am not expecting to add present size but i least one entry should be enough . Thanks a lot .
