Hi guys, I’ve noticed that there are somehow 2 SKPs showing in my render file. This is the reason why I still see some objects which are hidden in SU. Any ideas on how I can fix this?
Hello
Are you always syncing the models via the LiveSync plugin? Did you change the name or save location of the modeling file and sync again? You need to replace the model in the original file, otherwise D5 will recognize it as a new file, and there will be two models in a same file.
You can relink the model file via the plugin, and delete the other one in the object list.
