I need help with the application of materials
I hope this message finds you well.
I am encountering an issue while trying to apply a color material to the floor in my project. When I apply the color, it affects all the floors across the levels of the project instead of just the specific level I intend to target.
Could you please advise on how I can resolve this issue so that the material is applied only to the selected level and not to the other levels in the project? I export it from Revit, with the separator, and by selecting 'Export Selected Categories.
Thank you in advance for your assistance and guidance.
Best regards,
Hola, @a480107150 apologies for running into this issue, Is this happening to all of your files? or to this specific file only? Have you assigned separate materials for specific parts i.e. walls, floor, or ceiling? or double-checking it before exporting to Revit?
Yes, this is how I have my project, and honestly, I’m not sure what else I need to do to make it work.
Hi @a480107150,
Don’t worry I am here to help. We’ll figure things out. I scanned through the process that you mentioned and I need to have a few details coming from you. Could you pls provide a screenshot of this portion in your Revit file? I need to make sure that you have all the options and parameters.
Also, on your D5 Render, could you pls send me a screenshot of this portion?
image_2024_08_09T03_07_40_287Z
Thank you.
